sometimes runs lean at idle
Turbo Habanero
4,229
Tucson,AZ
peste noire;1838290 said:
as for fuel mods, none yet im waiting to get my stuff together so i can dump it in and get it tuned. stock afm. turbonetics 60-1 at 11 pounds.
THIS could be you problem I'm assuming at higher rpms is where you go lean and into the 12afrs ?
Your fuel pump is old and probably can't keep up. Be care full because 12afrs is risky under boost very risky
Compton74
355
Long Beach
peste noire;1838304 said:
well im at mostly 10.5-11.6 underboost so its not really at 12.
and as for fuel cut, well doesnt it start at 12?? cause im right around 11.
depends, in our area i say 10-12 but you do have a bigger turbo pushing more air, so it'd be sooner.
Turbo Habanero
4,229
Tucson,AZ
Fuel cut is not measured by the number of pounds...
12psi on a stock turbo is not the same as 12psi on a bigger aftermarket turbo.
peste noire
266
los angeles,CA
well ill double check to see if im correct about 11 but its cause i just put on my boost controller and wideband right around the same time so i keep trying to look at both wile keeping an eye out in the road.lol im gonna put a camera to see it as i step on it.
Compton74
355
Long Beach
an exhaust leak is really starting to sound like the culprit here
dewme5
10
Panama City, FL
peste noire;1838264 said:
i think i i do have a small exhaust leak but i guess i dont mind it running rich.
The problem with an exhaust leak, is the O2 sensor measures what the engine has already done. Toss in an exhaust leak, and you can suck in clean air which will alter the O2 reading. Now, the ECU is attempting to fix a condition which the engine never had to deal with. Definitely not a good way to go about things. Fix the leak before you bother trying to get a meaningful reading, otherwise you are wasting your time.
Turbo Habanero
4,229
Tucson,AZ
This obviously only applys to the stock 02 the wideband of course of no effect on the way the car is running.
So now you must narrow down where the exhaust leak is and is it before the stock 02 sensor ? If so it will affect the way the car runs.
