So guys, just got done with a buddy of mine fixing my BHG. Went with an HKS 1.2mm MHG and ARP Headstuds. Head decked and hot tanked, block gets a slight resurface. Torqued it to 90ft/lbs. Brand new oem toyota seals from bottom to top.
Everything thrown back on together. Two cranks later and she starts rite up and purrs like a kitten. Assuming there would be some smoke from the moisture/water from the BHG sure enough there is. A couple minutes later it doesnt wanna go away. Idle is fine. Just sits shy of 1200 rpms on cold start up. SOooooooo..... Here are my problems,
1. Temp in guage cluster never moved up after a couple minutes of purring.
2. The two e fans/ac condenser fans? Came on within a minute of start up? Very odd
3. Of course the smoke that still is coming out the tailpipe. It is not bad really, but its more than there should be in my honest opinion.
Conclusion- so to sum it all up this is what i believe may be wrong
1. I got the temp sensor and ac fan sensor plugs/nipples mixed up as to why the temp never moved up and also why the fans kicked in so early. So, if anyone remembers by any chance specifically which ones go where, that would be greatly appreciated!!!!
2. The white smoke is just the burning of the water/moisture from the BHG and new seal etc........so in other words, nothing i should be worried about?
Thanks a ton in advance guys! And hopefully i didnt word myself like and idiot
