Some 1jz electrical Q's
JonoTurbo
Going for broke
CT
Erkenz said:
I have a few questions as to where things go.
1. This is a ground right? And if so, does it ground to the alternator or the body?http://i148.photobucket.com/albums/s16/michigan_1jz/Ericspics112.jpg
2. I have this currently grounded. Is it supposed to be? If not, where does it bolt to?http://i148.photobucket.com/albums/s16/michigan_1jz/Ericspics116.jpg
Thanks for the help.
The first wire is the main power wire off the alternator. It needs to be connected to the two black wires which originally connected to the 7m alternator.
The second connection looks like a ground, but I can't tell where it is so I don't know what it should bolt to.
Erkenz
125
Michigan
Now, the first one needs to be connected to the wires from the 7m alt, but they're on different sides of the engine bay. What should I do?
Erkenz
125
Michigan
Thank you very much! Yet again I would be lost without these forums. And my 1j would not be alive today...
