[Solved]Spark Issue possibly ECU?
MySupra
importsoftexas.com
Dec 4, 2011
Houston, Texas
importsoftexas.com
So today I bought a multimeter to test out the harness and I found that it was not reaching the CPS but everything it had around 11-12+ so I tracked down all the 3/4 wires that go from the CPS to the ECU. I tested the 3 spots in the ECU and both gave me the results 0.01 in other words 0. So that has brought and simplified the problem, I believe it's something of the following.
- Bad ECU
- Bad CPS
- Bad Coils
- Bad Ignitor
Not sure what to do next any ideas before I start buying these parts?
By the way, I checked all the fuses and all are fine they light up my tester.
1989 Supra Turbo - 7M-GTE
Update: It was the CPS.
MySupra
importsoftexas.com
Dec 4, 2011
Houston, Texas
importsoftexas.com
Car has no spark, was tested the harness with a delimiter. What's not to understand? Ignitor had current, CPS did not due to the harness that I traced all the way back to the ecu and the current for those 4 wires were 0.01
mkiiichip
1,434
WI
I know I am going to regret posting in here......but,
The CPS creates its own voltage signal, once it begins to spin.
