EDIT 09/22/11 @ 4:16PM-
Please read post #34..
http://www.supramania.com/forums/sh...s-out-good..&p=1761381&viewfull=1#post1761381
OK. Just got back.
Edit: FYI the TSRM for the MKIV (USDM) says that fuel pressure with the ignition switch on should be 33-40psi (looking at it right now) and then 24-31psi with vacuum. So yeah, now I'm running around 45psi that seems normal. So.. back to square one I suppose.
Tests I ran:
-Injector resistance was around 14.5ohms
-Coil pack resistance was within spec 0.7ohms or something similar (spec says 0.54-0.84ohms cold)
-Both cam sensors measured 1.14ohms (spec says 835-1.4ohms cold)
-Crank sensor (replaced) measured 1.16ohms (spec says 835-1.4ohms cold)
-O2 sensor was 6ohms and spec says 11-16ohms at 68F .. it's like 85F outside not sure what to do. I'll try a spare.
-Engine off, map sensor gave 5v between power and ground, and 2.5v between signal and ground
-Fuel pump is running at 9v (turns out I did wire in the resistor and circuit opening relay, durr)
-I *did not* test the fuel return return line yet but will do it soon to see if there's kinks in there.
-On my spare regulator: Got the car running (had to hold the throttle or it would die though) and fuel pressure went from 50psi to 55psi. This was a 2JZ-GE regulator which looks exactly the same but clearly isn't the same part.
-On my stock regulator: Couldn't get the car running at all, however the fuel pressure base was 46psi.
Spark/air/fuel/timing:
-I have spark on all cyl, but my plugs are all soaked in fuel at this point. Have some coming as well as an AFPR.
-I removed the fuel rail and cranked. All injectors spray. No injectors obviously leak or are stuck open.
-All coil packs have strong power at the connectors, as do the injectors.
-There are no vac leaks. Triple checked.
-Triple checked the timing belt, all gears line up to 0deg and with a chopstick in #1 spark plug hole it's definitely at TDC.
When the car was running, it wouldn't rev unless I pressed the throttle hard. Revved very slowly. Sputtered a lot. Smoke out the exhaust. I expected black smoke but honestly it was grayish. Could have been water since it rained all day though so I'm not really using that as an indicator of anything.
My aftermarket regulator and new spark plugs will be here soon. I've always learned with cars, you need to fix any problem you know of before you proceed, even if you think it's unrelated.
Can anyone verify what pin on the ECU the MAP sensor runs to? I want to make sure the signal is making it from the map sensor to the ECU because if the map signal was getting messed up somewhere along the way, the car might inject too much fuel, right?
So, WHY am I getting too much fuel? Or am I? Perhaps my cam sensor is bad and my ignition timing is off, causing no ignition, causing my motor to be doused in fuel?
Just completed my Aristo swap and it won't start unless I crank, then disable the pump, then crank again it'll run off of all the excess fuel for a few seconds.
I'm seeing about 50PSI on a mechanical gauge at the rail with the key turned (pump @ 12v). Car will not run, that measure is with the engine off. Rebuilt the harness just in-case and everything is verified. Wiring at the injectors is verified, wiring at the coils, etc. All injectors and coils resistance tested. Coils are all giving out spark. Cam timing checked, re-checked, and re-checked again.
Replaced the regulator, same issue.
Thought I had a Walbro, found out from the PO I'm running a 290LPH pump. From my understanding, if the regulator was functioning, shouldn't the excess pressure be bled to the tank? Is this simply a case of my pump moving more fuel than the tiny return line can send back? Or is something else wrong?
I know it's over fueling on all cyl. because when the intake is removed all runners have puddles of fuel. Injectors are NOT stuck on (tested wiring) and no injector is leaking (did test with graduated cylinders) , and all injectors pulse correctly (tested @ cranking). Tested my map sensor on a buddy's car, tested igniter also. No codes or anything other than fuel pump ECU (78) but that's normal since I don't have a FP ECU, correct?
I have around $200 to fix this problem. Before I purchase anything I was going to run the return from the regulator to a bucket to test for blockage in the return line. If no blockage, the only solution I see myself is to grab an adjustable fuel pressure regulator and see if I can tune the pressure down a bit since it will be a larger diameter return (I assume the bottle-neck is the tiny opening in the stock regulator fitting where the o-ring is). Or add a resistor to my pump that is disabled via a relay somehow so that it never supplies more pressure than the stock regulator can return. (hobbs switch?)
Specs:
-1990 Supra MKIII
-Aristo 2JZ-GTE
-Completely stock (440cc) fuel system on motor
-Single 290LPH pump @ 12v
-Motor is single turbo'd
Any input would be appreciated. Thanks.
If you need more specs/info, you can check the other thread. Original thread got really crowded and the point was rather lost so I'd rather start a new more focused thread. The old can be deleted/locked if desired:
http://www.supramania.com/forums/sh...rouble.-No-codes-misfiring-more..-Added-video
OK. Just got back.
Tests I ran:
Specs:
-1990 Supra MKIII
-Aristo 2JZ-GTE
