solid subframe mounts
webbs7mgte
298
wisconsin
how rough of a ride willl solid subframe mounts give me. is it worth it? please toss me the pros and cons'. I have a guy who is looking at making them for me
gaboonviper85
3,236
Northeast Philly
highly doubt it will make the ride ruff at all....but im sure it will transfer alot of road noise into the car....you probably wont even notice a difference over "new stock".
becauseican
Vancouver
www.bicperformance.com
BIC already has these available. I have tried Aluminum, Nylon and now I have a prototype poly set on my car. They reallly tighten up the rear suspension. The is no more "floaty" feeling when going over bumps at speed. The steering response is also alot crisper as there is no shifting of the rear crossmember. It is a great cure for wheel hopp, if you jack up your car by the body /pinch welds, then take a prybar and see how much the subframe moves up and down, there is at least 1/2" of play, when you get wheel hop the whole subframe is bouncing up and down. The one drawback is that you get more NVH (noise, vibration, harshness) with these, you hear the road more and if your diff is noisy you will really hear it with solid spacers.......check the BIC section for pricing and pics if you are interested.
Randy
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I have the nylon, definitely one of the best mods on my car. No more "floaty feeling", better response, and I personnally didn't notice any more road noise.
