Soft pedal feel after flushing and bleeding brake system
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I recently flushed the DOT 3 out of my brake system with Super Blue DOT 4. My car has the ABS system removed and bypassed.
At the suggestion of a local mechanic, I gravity drained the old fluid out, then gravity fed in the new fluid, then used a vacuum bleeder. I found the vacuum bleeder had a lot of air and bubbles leaking in through the bleeder threads and hose seal. So I went ahead and bled using usual 2-person method, and no bubbles at all were coming out after going through a litre of fluid.
Unfortunately, I now have a very soft unresponsive pedal feel, and am wondering if the master cylinder needs proper bleeding or the entire system needs pressure bleeding?
The brake fluid on the front resevoir in the master cylinder did get quite low at one point, but did not seem to get down to the metal of the master cylinder. The brake pedal feels hard when the car is off. Suggestions?
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
well i'm sure this isn't your first time bleeding brakes so i would say you got the air out. like IJ said i would check out the mastercylinder. look for fluid on the floor.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i had to bench bleed a reman master cylinder and one that i rebuilt myself, don't know if youll have to do the same. seems like you might if you ever let the master cyl run completely dry.
throw it in a vise and use a #3 philips to push the piston, bleed it like you would a regular caliper (but you'll need a few plugs/fittings to direct fluid and evacuate the air bubbles)
Satan
Tampa
On my 1990, I could NEVER get the sponginess out of the brake pedal. The fluid is clear and is new, 'cause I've gone through a gallon (at least) of fluid. Must've tried bleeding 25 times and still feels spongy. No leaks that I can see.
I have a new set of lines (from the master all the way to each caliper) and a newer booster to install, when we get ready to do the 2J swap into it. I'll probably also change the proportioning valve.
So, I'd try to 2 man bleeding deal again and if the master is not leaking, maybe suggest that you look at the lines, the booster, and possibly start with the proportioning valve (though I do not really know what the symptoms are when this goes bad).
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
air in master or your booster is leaking
how many pumps does it take to get stiff pedle with the car on you chould very well have a booster leak
808mkiiisupra;1179555 said:
try this...turn car off. pump the pedal till it gets really stiff. at this point feel if the pedal moves slowly down...more likely you have air in the lines. i would gravity bleed all again just to make sure. hth
808mkiiisupra;1180153 said:
hey thats what i said hahah but yea check inside the cabin or on the carpet for fluid...
You did?
Clip
Oct 16, 2005
2,738
9
Virginia
its easy to get the air out of the master cyl if you bench bleed it, but you'll need to re-bleed it at the four corners after you've disconnected the master.
