ok i think ive found my idle problem, there is supposed to be an input to the ECU marked "ELS" for the "external load input".
i looked on the mkiv wiring diagram which also has an ELS input to the ECU.
the wire is coming from what is labeled as a diode "for idle-up" with 3 wires total.
1. Blue/Red- from the diode to the MIR-HTR 10A Fuse
2. Red/Yel- from the Diode to the ELS pin on the ECU (pin 15 on the 2jz ecu and it is located on the (19 used) 28 pin total ECU plug on the JZZ30 ECU)
3. Grn/Org- from the diode to the Panel Fuse 10A
the wiring diagram says that this diode is located behind the left side of I/P which i am assuming means intake pipe.
does anyone have a picture of this diode?
