so, what is your trick to installing your r154 to your motor?
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
i ran into this problem when i did the 5speed conversion. it was a HUGE pain in the ass. the bellhousing is massive. so, i'm looking for some tips to install the r154 to the motor while the motor is in the car...:1zhelp:
thanks!
-t3d
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
well, i don't have a torque dampener, but i loosened everything and the bellhousing still hits the floor board. i was thinking of just removing one the motor mounts?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
wtf? It's not that hard to get back up there - I don't even bother with loosening the motor mounts.
The shifter isn't installed, right? ;)
Seriously, though - pressure plate and disc on the tranny input shaft, flywheel bolted onto the crank on the engine side, put it on a roller jack, jack it up, slide it forward, up, forward, repeat until you can line up the bolts.
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
lol that's RIGHT. i remember now! put it on the input shaft and then i tightened the bolts through the inspection holes. thanks! now i gotta wait 'til monday to fucking work on it, 'cause it's at school =0(
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
ahh i remember when i made the same mistake ..... i was so used to do installing the w58 and i spent about 1hr to figure this out. Dont bolt down the PP and disk instead put them on the shaft and then install the tranny :)
speed
Gone. Email me.
May 27, 2006
1,045
not here
www.timduganphotography.com
Pff, i've done it with the clutch and pressureplate already bolted down. Just roll the transmission onto your chest, and push up with your arms and knees.
No wait, that method sucks balls....
I did ^^ a few times then realized i could use a floor jack, made life a lot easier.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Pshh you guys..
I did as MDC stated (loosened motor mounts, jack up front of motor), and I had pleanty of clearance to install my quad plate (which the PP cannot be bolted down through the inspection holes). The quad plate sticks out about 5 inches off the flywheel.. so I know you can do it :)
It's pretty easy even without a car lift. just get a tranny jack to lift the transmission nice and stable. Then get under it on your back and muscle man it in ;). Make sure you have someone to spot you in case you get fatigued.. which I aways do because I'm not diesel or anything.
EDIT: I'm w/ speed.
quake
toyota tech
Apr 13, 2005
619
r.i.
at work with a lift i drop the tranny in 15-20min.
on a lift first remove the shifter
next the bolts on the fan shroud
next get everything else out of your way drive shaft etc
after that place a jack with a block of wood on the crank pulley and jack it till the fan hit the shroud (don't break anything go easy)
now your tranny is at the right angle install / remove as needed use the inspection holes to bolt/unbolt the clutch use thread lock on all bolts in there
if on ground make sure the car is high enough
