So close to being done but just one thing HELP!!!
turbomk3
Ok well i have the car done with the rebuild and if i can get a quick answer without pictures then that would make my day and i could fire up my car tomorrow! I have two hoses inbetween the upper and lower intake mani. They are both the same size except one is near the front of the car and one is near the last runners. I know for sure that one goes to my FPR return line to the tank, the other one i have absolutely no idea where i could go i ahve searched everywhere! Im thinking the one closer the the front is the return line. i also removed the egr? it could have went to the bottom of that circle thing...idk im just rambling on! i need help please!!!!
nate
turbomk3
forgot to mention that the line on the right appears to go around and behind the head/block on a hardline...that may help and i think that that other loose one is my fpr return line
mazzer
438
st.louis,mo
theres a little coolant line up around the front of the manif. blow air through it with a blow gun. you should hear where it goes
supra90turbo
shaeff is FTMFW!
MA, 01440
tlo86temp said:
check the tsrm
lol
best advice we can give you!
click me for all the info you need.
also, post pics if you need quick help. telepathy doesnt work well through all these firewalls and junk. lol
Arther3
Remember SOGI? I do
Starkville, MS
the one on the hardline goes to the throttle body. check to make sure there is a hose going to the IAC as well. the fpr return line goes from the fpr to the j-tube(obviously).
