So hear is my issue. I finally got the car running after a lengthy HG repair job and a few other minor upgrades and am trying to set the final timing. I had the car idleing fine at around 680RPM the other day but found that that the cam sensor was off slighly because the timing mark on the crank wasn't lining up with the timing marks on the front cover. So I readjusted the cam sensor and tried again but now the idle is bouncing up down between 1200 and 1800RPM. The timing marks seem they will line up but I can't tell for sure will the idle bouncing like that. I checked for codes and I have none, no aparent vacuum leaks. I'm just confused on why it just started to do this and all I touched was the cam sensor. I really want to get the car back on the road and I'm so close, it's just setting the final timing that holding me up. Any ideas or advice will be greatly appreciated. Thank you.
