***SM Member Horsepower List***
Torque
255
In your home
Thanks Crisp, unfortunately that motor spun a couple of bearing 3 months ago. The new motor should produce even better horsepower numbers. I've ungraded almost everything on the new motor to include cams. we'll see what it does in a couple of weeks.
Enraged
A HG job took HOW long??
22
Victoria, BC, Canada
Mods in my build thread, link in sig, but still stock turbo and stock injectors on an AEM, on a Dyno Dynamics dyno tuned by Chris at 5252Motorsports:
320rwhp and ~360ft-lbs
HP vs Torque:
HP vs Boost:
mk3-4-me
669
Milwaukee, WI
7mgte
JE .20 over
Eagles
Fully balanaced
Precision 6152
560cc evos
AERO AFPR at 32 (vac on)
ETS IC kit
Aem cam gears (not adjusted yet)
Rebuilt head (stock)
1 pc DS
6 puck clutch
11lb FW
4 In Intake
Maf-t BASIC!!!!! no its not PRO lol
greddy Type S
R154
3 inch turbo back.
391 RWHP at only 15 psi!! AFRs at 11.8:1. got some more HPs with a final tune im thinking!
THANKS
87turbosupra
"The 87' Burgundy"
Apr 11, 2005
97
Colo Spgs, CO
Just finished dyno tuning.
400 rwhp @ 14 psi. Ordering a stiffer wastegate spring and will be back w/ 25-28 psi.
[video=youtube;ARdBovcxnv8]http://www.youtube.com/watch?v=ARdBovcxnv8[/video]
[video=youtube;ex9Zd7Tqyeo]http://www.youtube.com/watch?v=ex9Zd7Tqyeo[/video]
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
400 rwhp @ 14 psi.
That's really good! What type of fuel and what were your afr's? Looks a little on the lean side; but, I could be looking at the wrong trace.
And did I read the torque right...369?
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
^^^ Had a guy in my area (IndyMKIII) ask me if I wanted to drop by his Tech class and do a pull on the dyno tonight. Running 93 pump gas at between 17~18psi range we did a couple pulls. The pull in the video is showing an out-of-focus 427.14 and the image of the chart is just over 420.80hp at 368.22tq. Only change since my summer numbers at 394hp were the cam pulley adjustments I made yesterday to remove a little overlap and shift power a bit higher in rpm band. Torque was pretty much the same on the summer pull, so just shifted HP up and increased about 33hp overall. I retarded both intake and exhaust... -2* on intake and -1* on exhaust, everything else is essentially unchanged.
We did a first pull at about 1psi less and it was about 20hp lower at 408hp. That's about right. 20hp/1psi or so.
I think that's decent street numbers for a 120k mile plus original stock bottom end and a few piggy-back components from HKS. I'm running 550cc and have some headroom, and the cam pulleys are still just being diddled with, so optimum is an unknown yet. I don't want to get too greedy, either, since everything works well and I'm having fun when I drive the car and this is what it puts down to the road anytime I drive it around.:biglaugh:
BTW, since the cam adjustments, I didn't really do any tuning since yesterday, and you can see the "dip" in the curve that would likely work it's way out with some fiddling. I also have it running really rich to be safe... upper 10's to very low 11's on the two pulls.;)
-crisp
crisp
May 25, 2007
1,785
Ohio
Turbo Habanero;1802277 said:
Hey crisp
what piggy backs are you using?
What turbo?
and last but not least are you on stock cams and did you do any head work ?
1) Almost every HKS component... and early one's to boot. (PFC F-con, EVC, VPC, GCC, IPM, SBC, EARLY smaller IC kit complete, etc, etc...)
2) T04z (Barely puffing... but since bottom is stock, I usually only run 15~17psi range on street at high end... runs good at 12psi as well!:biglaugh:)
3) IJ head. (Everything.;))
NOTE: Head is WAAAY overbuilt for what I am doing with it at the moment... but it works great and purrs like a kitten! (Valves, porting, 280 cams, etc...)
-crisp
BillyM
MK2 + 7M = FUN
Mar 3, 2006
69
Greenville, SC
357rwhp 327rwtq @ 11psi (creep)
Junk-yard 7m-gte /w MHG, H-trim/clipped CT26, RonR FFIM, NPR intercooler, VPC, 440's.
https://lh6.googleusercontent.com/-vzo1TBkVN0M/T0rzE75IpxI/AAAAAAAAEGQ/xggV-fITcDo/s800/IMG_0907.JPG
...~40,000 miles on swap /w numerous track-days, unknown miles on motor, worn rings (1qt per tank of gas)
Never let me down yet, and decently zippy in a 3000lb car...
Obviously not on the list, just documented here in-case 8 other 7m-gte folk get removed? ...lol.
--billyM
*Below*
Thanks Habenero, it's been a really great setup for me and I can't speak highly enough to the reliability of the stock 7m. I am going to tear it down sometime this summer and re-ring, but otherwise leave it be. I've carried around drop-in 550's and the matching VPC chip forever, but like you said, it's making darn good power at only 11 (11.4psi to be exact) lbs of boost and is plenty quick while still being trustworthy. I hop in this car and drive 12+hrs without a second-thought, or fire it up and do 4hrs of track-time without concern. I don't want to risk that for an extra 40-50hp...
MK3Hitman21
92
CALIFORNIA
Where can I go to resize pics. Completely stock 1j, with emanage blue and boost controller. Still tuning ran fat rich 10.0 on wide band. Roller coaster ride on the chart.
mark1987supra
work in progress
May 26, 2008
74
Des Moines
7MGTE, PROEFI, E55, SP61, 25 psi, 1200cc inj., BC 272 cams, Weisco 20 over, Crower rods, Hks Stopper, ARP Head and main studs.
It was winter when the car was dynoed which is the reason for the E55 blend.
