SM GT4 Challenge!
MKIIINA
Destroyer of Turbos
Plano, TX
ma71supraturbo said:
Thought it'd be fun to have a challenge each week with a mk3 supra on a different track. To start things off, a Laguna Seca Time trial with a Turbo A (unmodified except for soft tires). You don't have to buy the car, just go to the arcade section, them time trial, then mazda raceway/laguna seca, then pick toyota, and Turbo A.
Do Not change the power or weight (in the "quick tune up"), but put on the softest tires available (sports soft i believe).
Current time to beat: 1'42.546
mines faster...... 1'42.135........ read my post on page 1 ;)
MKNTRAXX
Loves tire smoke
Orange, va
Still don't have this Turbo A you guys keep talking about.. (take a pic)
using the JZA70 .. The Toyota Supra 2.5 Twin turbo R.. untouched
I just ran a 1'41.799
edit.. that dropped to a 1'41.621
ma71supraturbo
Redding, CA
www.geocities.com
Hmm, I guess it isn't just a standard car everyone can get at the beginning -- my bad. For the weekend, lets do the exact opposite. Fully built mk3 (7m or jz). I think MKIIINA ought to pick the track since he was fastest with the 7m (the jz has another 50hp on it)
MKIIINA
Destroyer of Turbos
Plano, TX
Thanks MA71SUPRATURBO for letting me pick the next track :) I'm going to set it up like this:
Turbo A is the car of preferance but the 1JZ can be used is it has the same HP (or less) as the challenge starters car. (Makes it even and people can then use both cars)
Challenge starter can post their times as a benchmark for people to start for.
new challenge for the weekend:
Costa di Amalfi - Forward
2'04.722
Car: Turbo A 88
HP: 400
Mods:
Port+Polish
Racing Exhaust
Chip
Sport tires Medium
Turbine stage 2
Racing IC
Racing Brakes
Racing Suspension
Normal Trans
Triple PLate clutch
Racing flywheel
Normal DS
Rollcage
Lightweight stage 2
MKNTRAXX
Loves tire smoke
Orange, va
ok..I think the car should always be the jza70(keeps it simple as everyone has access to it)..
Only mods should be power and weight in the quick tune up..
this keeps it very simple and effective
ma71supraturbo
Redding, CA
www.geocities.com
Current Time:
2'11:054 w/ room to improve
My suspension settings (in case someone else wants to try my unusual approach):
Spring Rate:
18 front / 16 rear
Ride Height:
97mm front, 100mm rear (may raise this a bit as getting airborne sucks)
Compression/Bound Damper Settings:
7 front / 8 rear
Rebound Damping:
9 front / 9 rear
Camber:
3.0 front / 1.0 rear
Toe:
-1 front / -1 rear
Sabilizers:
1 front / 1 rear
Brake Bias:
3 front / 7 rear
TCS 5 (all others turned off)
0 ballast weight
