Slightly Rough Idle
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
Did you gap the plugs?
Do you have a vaccume gauge.
Like so.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Zumtizzle;1389885 said:
^whats your power band and which NGK plug did you use?
BCPR6ES or BCPR7ES?
Power band, I have no clue. Plugs are BCPR6E. They are the V-Power ones.
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
Check Resistance of the Coils.
Check Resistance of the SPark Plug Wires.
A conventional plug wire has a resistance of 10,000 to 15,000 ohms per foot of length--if it's measurably higher, the wire probably is bad.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
supra_guy;1389888 said:
Your idle is fine I've heard it in person..the ticking I would be more concerned about.
Dude, the ticking is nothing. It's just a mix between old pulleys, valves, and injectors. Listen to some other 7M-GTE's, they'll make noise.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
The plugs and wires and brand new.
pulleys dont tick, the top end makes some noise but not really. mines quiet as a mouse. and injectors usually arent that noisey either.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Guys, don't worry about the ticking part. It's just injectors and valves, it's always done that. A lot of 7M's I hear make that sound.
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
Alec;1389899 said:
Take a Mechanics Stetescope and put it over the cam covers.
If it's ticking there it's fine but i wondn't leave it ticky for various reasons.
But i'd check clearences. Too tight can burn valves and back firing. :(
When i change plugs i perform a complete vehicle check.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Zumtizzle;1389900 said:
Means nothing. :nono:
And my motors are Quiet, and my cousins motor i assembled has a 3.5 Straight pipe.....:)
I'm just saying, the ticking isn't anything abnormal. Sounds just like injectors. It's not going to do any damage.
supra_guy
29
Illinois
Zumtizzle;1389897 said:
Check Valve Clearance.
I check this too when i do my plugs. ;)
+1 Some do tick but in your video it was ticking loud enough to be heard all the way from the back of the car by the exhaust and you could still hear it. Do what you want man we are just trying to help you. All I have to say is your idle was completely fine when I heard your car, I don't know how it is now after you changed your stuff but it should be just as good if not better.
It sounded pretty good to me on the video and the RPM is good. Might need to be timed...and it sounds like valve lash needs to be set.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Probably something with the valves. It's not as loud in person. The idle thing is probably timing.
