Slave cylinder???
MK3Supraman
67
olathe,ks
ok so
new trans(r154)stage 3 6 puck,fidanza flywheel, rear main seal,clutch master.
has about 1500 miles on the setup
was driving and clutch releases normally up 3/4 ways
well i decide to run it and i bounce rev in first gear on purpose and suddenly my clutch starts to release like instantly off the ground
couple stoplights later back to normal. i do it again to see and sure enough same thing
but goes to normal after awhile
when it gets short it feels like it rubbing or something when pushed in.
anyone? its rpm related cuz it only does it when i hit 6-7k
gaboonviper85
3,236
Northeast Philly
It's not a hydrolic issue if you notice things only act funny when you rev high....sounds like a pressure plate issue.
Although I'm somehow confused by your post....I understand what the problem is but I don't understand how rpm can make your clutch act funny...usually a clutch will just blow appart at high rpms if anything..
MK3Supraman
67
olathe,ks
yes proper adjustment
only thing i could think of is the pressure plate comin loose but i check and everything is tight
i dont get it
wouldnt it be all the time if it was the clutch set?
could it be the slave though? everything is replaced but and its lookin a little old but dont see how id be rpm related
FloTex
Crankin since the 1900s
Aug 13, 2008
47
Tallahassee, Florida
Check the clevis/pin on the brake pedal arm where it connects to the clutch cylinder. I had one break a weld at the base of the clevis pin/cylinder rod and it did not always fully engage.
Also check hoses to make sure you don't have any blown layers that may be swelling.
