Siemens Deka fuel injectors leaking? and tuning with SAFC2
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
is it possible for them to leak on the side where the little hole is? I got these from driftmotion and one seems to be leaking from there. I will be taking the rail off to see if a new o-ring will cure the problem but these are new to begin withhhh
Lastly, will the safc2 change a/f under 1000 rpms using the 1000 rpm selection? it doesnt seem to be working for me, but it was before I put the new injectors in so I dont know whats goin on with it
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
I am using the o rings that came with the package... they are green too ( i dont know why)
680cc injectors, walbro 255, aeromotive afpr, stainless feed/return lines...
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
Where is it leaking top or bottom?
Is it a little o ring on the bottom?
What injectors did you have before?
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
it appears to be leaking from the top, I havnt taken it apart yet to see if it is broken but they are brand spankin new. I had stock injectors prior
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
Darn, i didnt put lube on it, I thought you shouldnt put any on there because it would later mix with the gasoline and that is a no-no.....
What lube should I use? K-Y brand? haha just kidding
I have some standard 3in1 all purpose household oil in the garage that I pretty much use on everything if that would be okay..
