shifting problem only in first gear
MKTURBO3
93
NEWYORK
When ever im in nuetural and go in to first i have to like give it all my strength and force it in? does anyone know what could cause this to happen
lifted
157
memphis
syncros are going out. shift to reverse first and then to 1st. this happens from riding the clucth. instead of letting the clutch out evenly with the gas when starting out, your giving it more gas and slowly letting the clutch out hence the term riding the clutch. i know because ive done it to 3 cars myself.
Dunckel
2,949
Spokane, WA
each gear has it's own syncro. (I think) I could be wrong. If I am, sorry, it's late, and I just want to help.
Dunckel
2,949
Spokane, WA
Stop on a slight decline. Put the car into neutral. Try to shift into first. Is it tough?? Now, let off of the brake pedal and try to put the car into first while the car is rolling from a stop. If it goes in easily, it's gotta be your first gear "synchronizer ring". (thank you johnathan) Again, I could be wrong, but that is my understanding.
MKTURBO3
93
NEWYORK
maybe because i put in royal purple..i just read all the post and yea i just ordered 3qts of redline mt90.. i believe its 3.2 qts right i can get away with that .2 right?
OneJoeZee
Retired Post Whore
aboard the Argama
Big Wang Bandit said:
Don;t believe reverse has a syncronizer. But thats besides the point :p
Also, FYI, we don't have a 4th gear, we have a direct drive in that case
Yes, there is no synchro on reverse. Which is why it will grind unless you put the transmission into a forward gear 1st to stop it or just wait a few seconds while it stops on its own.
It's also a straight cut gear IIRC.
