Shakes
Shuffles099
Chandler AZ
Hi My Son has a 89 turbo- well last night he came home saying the it was shaking really bad when he comes to a stop. Well i went out this morning and the coolent light was on added coolent and drove around at little, Seems like it shakes after it warms up. any suggestions? anything will help! Single mom not a lot of money so I hope it is not a big problem.. :icon_conf
johnathan1
Supra =
Aug 19, 2005
5,056
Some basic info about the car would help. Is it 5-Spd or Auto, Turbo? And when you say it shakes, do you mean when it's idling, the engine runs roughly? A little more info would be great.
edit: I just realized you said the coolant light was on...That's not a good sign...The coolant has to be going somewhere, was any work done on the cooling system recently? There is either a coolant leak somewhere, or you may be looking at a Blown Head Gasket (BHG), which is a common problem with Supras. Does the car smoke at all?
Shuffles099
Chandler AZ
Sorry! Its a Auto Turbo, and yes when it is idling and coming to a stop. And no the engine does not run ruff. Up till last night when it was running it was hard to tell it was running it was so smooth.
Shuffles099
Chandler AZ
johnathan1 said:
Check my edit.
No It doesn't smoke at all. Has just been throw DEQ- Emission also. It only took about a quart of fluid when I put that in. It does have a small oil leak. But nothing major. And no work has been done that I know of. The car has been sitting for a while. But really only a couple of months.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
bigunitpitcher22 said:
I read a report online about brakes, and there is no such thing as warped rotors. The get cracked but not necessarily "warped"
You read wrong.
I can show you a rotor that is so warped it wouldn't turn any longer.
As for the car shaking comming to a stop. Is it more of a wiggle, as in the car wiggles from side to side?
If so, you have a tire problem. Either one is broke internally, or about to blow out.
