serpentine belt
ma70mkiii
139
ohio
I bought a serpentine belt for my 1jz and it is way too long adn I was told to get one from a 2jz. is that the correct belt or can someone tell me which one I need?
lagged
1991 1JZ
new rochelle
Posted by Marty1MC on supraforums:
For a 1JZ timing belt:
The 1988+ Isuzu Trooper 4 cylinder 2.6 liter engine (4ZEL) uses the same belt as the Toyota 1JZ engine. So instead of getting a belt from Japan (~$100) you can pick up an Isuzu Trooper belt locally at an auto parts store for about $30 US. Make Sure You Get The 4 Cylinder 2.6 Litre Engine Belt!
Timing belt specs: 137 teeth, 25mm wide
JustinGotA1j
532
Chilliwack
what joe said. and just in case. if you are running the 2jz waterpump like me and many others are then just get one size smaller than that belt.
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
One size smaller? What do you mean one size smaller?
JustinGotA1j
532
Chilliwack
Well the part number corresponds to the width and length of a belt. If you are running a mechanical pump then the water pump pulley is slightly smaller so therefore you will need a shorter belt by a half inch I believe. Your local auto parts store should know what you mean when you say I need a size smaller unless they are completely retarded.
JustinGotA1j
532
Chilliwack
Dylan JZ said:
I was under the impression that the 2J serpentine only fit if you did the mkiv water pump conversion.
That could be possible but I never bothered trying a 2J belt. I just grabbed one size smaller than the belt for the hydrofan.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
I think I'm gonna go get a OE 2J serpentine and see if works with both the hydro and mkiv waterpump as the engine isn't in the car.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
935motorsports said:
A 2J belt *does* fit the hydro. However, it is not proper. The proper belt will put it at proper tension.
We stock all sizes w/ or w/o AC.
Is the tension correct if you convert to mkiv waterpump?
ma70mkiii
139
ohio
mine has stock hydrofan but im converting to the 2j water pump but the belt that i got it way too long. i have about 5-7 of play. i got mine at autozone and mine still has the ac compressor attached but i will be removing it soon. no ac or heat in mine. why do i need ac in the summer when i have targa. lol.
