Sensor question...
Nopaint
110
Jan 30, 2007
172
GA
Hey guys,
I was cleaning up my shop yesterday and I accidentally kicked the intake manifold and broke this little sensor on the bottom of it... It's got a vacuum line that runs into it. It's also held down by two 10mm bolts...
I was wondering if anyone new what it was and what would happen if I didn't use it? Or where can I get another one from?
Thanks
I'll try to have some pics posted up later....
tissimo
Stock is boring :(
Melbourne, FL
you broke your map sensor.. (if 2jz)
edit: on the bottom like under the runners? if so might be a VSV.. are there (or were) 2 vacuum nipples on it?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
if it has 2 10mm bolts holding it in place then its prolly the VSV because the 2J map only has a one bolt bracket IIRC
tissimo
Stock is boring :(
Melbourne, FL
2jz map sensor has 2 bolts and bolts directly to the intake manifold plenium.
