Seach Turbo 600PS / Shop
watts
7
d
Hello,
i came from Germany and a have some questions about my 92 Supra.
I have rebuild it with:
Wiseco Pistons
Eagle Rods
ARP HEAD MAIN Studs
HKS 2.00 mm Head Gasget.
In next weeks the Greddy Ultimate comes in, 550cc Fuels etc
So i have to buy a Turbo for 550-600 Ps. The Turbo should come early and i will drive it on Track and on the street. I will NOT drive on 1/4 Miles.
So have you any Idea which Turbo is the best for me? Have you experience about the performance.
And i need a good and cheap Shop where i can buy Radiators, Intercooler Kits and Celvitte77 Bearings, Bitz Nur Spec etc. who ship it in one pakage to me.
What Clush sould i take?
Have you any experience about a t3/4 Turbo Manifold? The Cheap MAinifold from Ebay are the good or is that garbage ??
Sorry about my stupid English.
I hope you could help me
mfg watts form Germanyy
mdr40z
arkansas
welcome and Merry Christmas, this post may have some helpful info
http://www.supramania.com/forums/forumdisplay.php?f=109
I've had my ebay mani many years, I bought it when everyone said they were junk............ no leaks, cracks, etc.
As far as turbos go, it really depends more on your $.
If money is no concern I'd get a ball-bearing Garrett or Turbonetics, maybe a GT3071 or so.
The biggest problem when stepping up is keeping the trans together and/or making sure you've got a good tune.
g/l spend money
watts
7
d
Hello,
thanks for you quick answer.
Also i will build up the 7m that the engine is save.
It should be a garett or a turbonetics Turbo.
You know a Turbo how comes early and could hold it for Drift challenges?
550-600PS
Did you know a good shop?
watts
7
d
About the clush what stage should i take? What Brand is good for 600 PS
About the Turbo very nice but a litte bit expesive.
The Turbo should cost something about 1000$ - 1200$
NOT going to happen on a 3540r on that fuel without something like Methanol/Water injection.
The response thing becomes a problem soon as you go bigger.
Maybe a 67>70mm with a QuickSpool valve would work for you.
If you get a 321 SS Header from somewhere like SSAC in the USA you can't really go wrong, mine was perfect with no sign of any cracking or defects.
Clutch I'd be looking at a quality twin/triple then it's in there for a long time, any of the singles at that sort of power level are going to be ugly to use.
watts
7
d
i think about a Methanol/Water injection but does it realy bring the rest Power?
What kit could you think about recomment.
About the Turbo, a 67 trimm i think is realy good. Garett is the best i think.
Have you a good shop where i can buy all the thinks, so its cheaper with the shipping.
thanks a lot
MW doesn't "bring" power but it allows you to run more timing/boost and that is where you find the power.
I run a T04z and like the way it makes it's power but it was a bit lazy on the 3.0L once you get into Turbine housing that allow a decent top end, this is why I suggested the Sound Performance Quick Spool valve that way you can run a nice loose turbine housing for top end power but still have the spool of a tight one down low.
Can't think of too many Vendors that can supply all of your needs in one shop, give George at Raptor racing a try he may be able to source all of the parts you need.
watts
7
d
The shop doesn't exists.
Water Methanol i think i should take.
What do you think about the Garrett GT4094R
Did you click the link I provided?
<edit> Ahhh I see what you mean now!
His e-mail should still work and you can always post in his Vendor section here and ask if he can supply the parts you need.
SWD Fredester 3
674
baltimore maryland
watts;1477673 said:
raptor racing
Not to interrupt IJ, but you can go to the Vendors page on here and find Raptor Racing. Send George a PM or E Mail with what you want. Also check out Rich @ SIP and Aaron @ Drift Motion.
As far as the GT 4094 R, I can let you know in a little while. I have one on my build with a lot of supporting mods. Adding a Water-Meth kit from Supra Sport.
They sell a Labonte kit that Jack highly recommended.
And listen to IJ, he is the MAN for info!
-Fred
