Alright, been doing a fair amount of searching, and I cannot come up with the parts list or what's required to use the Toyota bellhousing with a th400 trans.
Could someone assist me coming up a list of parts needed to use the Toyota bellhousing? (I am currently running a W58, so it would be easy enough for me to re-utilize the factory bellhousing).
I have found the parts needed to use the GM bellhousing.
They are as follows.
1. JW Ultrabell for TH400
2. TH400 transmission
3. Block Adapter Plate
4. Flexplate
5. GM Torque Converter
6. Custom Driveshaft
7. TH400 shifter
8. Trans cooler
Read more: http://www.clublexus.com/forums/sc-...300-th400-swap-method-help.html#ixzz40wDErb5w
4. Flexplate
7. TH400 shifter
8. Trans cooler
