Quick question would a Sc300 radiator fit into my 2jz-gte swapped MK3?
D deazndude New Member Aug 29, 2011 67 0 0 Orlando Oct 25, 2012 #1 Quick question would a Sc300 radiator fit into my 2jz-gte swapped MK3?
hvyman Dang Dude! No Way Man. Staff member Apr 17, 2007 12,568 1 0 Fullerton,CA Oct 25, 2012 #2 Iirc it's wider so it might not clear the frame rails. And it wouldn't mount. And you need the rubber mounts.
D deazndude New Member Aug 29, 2011 67 0 0 Orlando Oct 25, 2012 #3 Alright thanks a lot, guess i'll just go another route then.
hvyman Dang Dude! No Way Man. Staff member Apr 17, 2007 12,568 1 0 Fullerton,CA Oct 25, 2012 #4 If looking for upgraded radiator just use a koyo pwr or fluidyne. All will work with ls400/7mgte and 2jzge/gte clutch and blade setups.
