Hello. I am planning on swapping sc hubs into an 88 and a 90 Turbo with ABS and would like to retain the factory ABS. I am aware that the sensors are different and I will need to splice the wires for those.
I sthere any way to know if the readings will be off since the SC's have a different style of ABS ring than the MK3 supra?
I see that a few have already done the conversion and this is the last part of the swap I am unclear about. Already got the bushings, outer tie rods and caster problems solved.
Thanks in advance.
Thanks in advance.
