Safely How Much Boost..
LEGNA
80
CT
Very simple how much psi should one try to achieve on stock internals before running into problems .... i herd that 15 psi will not damage anything but anythhing over 18 psi will start to break things.
Dirgle
Conjurer of Boost
Pauma Valley, CA
PSI isn't a good way to measure how much power is safe. 18 PSI is much more dangerous on the tock CT26 than on say a SP61.
HP is a much better measure. Some people have touched 500hp safely on fresh stock internals. That is some thing you will not be able to do safely on a 200,000+ mile motor.
A little more info on your car and what you’re trying to accomplish would help in determining what would be safe for you.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
boost and boost till it blows up.
rebuild motor
set boost 2 psi below where it blew up
Now you know the max boost ..... :bigthumb:
