safely boosting
Moved. This is not a introduction thread. Please be aware of where you are posting threads.
To answer your question. You need fueling and tuning to run high boost. I suggest you read up on what it takes. It's more than just raising the boost to make more power.
mecevans
1,295
M-bay, cali
Stock fuel system/ turbo at 7psi i can hear pinging up steep hills with 89. I think i should be able to do 10psi with 91 and stock cooling systems. More than that i plan on using 95 from the local track (laguna seca) until i get methanol injection.
bioskyline
1,236
powell river bc
whats your supporting mods? turbo? ic and pipes? what injectors? fuel pump upgraded? any fuel managment? otherwise as stated 9-10 psi is max for the stock fuel system
7mgteforlife
8
Arcadia, WI
I have a 255 walbro,550cc injectors,venom fuel pressure regulator. For fuel managment going to be running an hks vpc with a 550cc
rom and an safc2 controller,turbonetics 70 trim? (bought it used), stock intercooler, aftermarket ic pipeing i think 2.5" diameter.
---------- Post added at 10:16 AM ---------- Previous post was at 10:11 AM ----------
7m's never break they run on hopes and dreams lol.
---------- Post added at 10:30 AM ---------- Previous post was at 10:16 AM ----------
And sorry guys for posting this subject here i'm new to this whole "fourm thing" and didn't really know where to post this question.
bioskyline
1,236
powell river bc
ok thats a bit better. 14-15 with a basic home tune, though a wideband to measure to AFR would be be a good investment. if you have a pro tuner play with it you could prob run 18.
tomsupra8683
82gts7mgte
Mar 31, 2007
105
puyallup
with the high compresson i cant seem to run more than 8psi.The afr's are good but need more octane.water meth injection is in my near future.At 8psi my car will spin the tires in second and when shifting hard into 3rd and i run riken 16x8s with decent tires.
tomsupra8683
82gts7mgte
Mar 31, 2007
105
puyallup
Turned out my wastegate dosnt like to be shimmed,im running a manual boost valve and i can run 10lbs of boost no problem but above that i hit the fuel cut.
Turbo Habanero
4,229
Tucson,AZ
Im on the stock fuel system and my car runs around 10.5 to as much as 12.7 depending on weather conditions.
Im only running 3inch exhaust and driftmotion intercooler. No boost controllers should i be worried about upgrading the fuel system? It does sem to be running really rich between shifts (Backfire's when ran hard) But i figured it was due to Vented BOV and No Cats or restrictions on exhaust?
