SAFC settings
tte
Breaking In - in progress
Northern California
And yes, I have searched and read alot of posts on it.
I bought it off a mk4 owner so its set to afl.
1/. How do I set the SAFC to Karman?
Do I go under "Settings" and channel 1 and do the same with all the channels? The Throttle,rev and correction settings are okay.
2/. The current settings for THR are LO-94%, Hi-96%.
Do I need to change these?
Cheers,
Roy
Dunckel
2,949
Spokane, WA
well, IF, it is like the safc2, try going to etc, sensor type, and choose....karman ftw.
if it's not at all like the safc2, then i have no clue.
good luck.
Ninja Edit: no one saw anything
Idealsupra
Orlando
www.tampabaysupras.com
go to the main menu...then go to ETC then sensor type then move it to karman..then back out....
as for the throttle points i normally put it to anything in the 10% for LO and around 50-60% for HI its just when the maps "kick in"
tte
Northern California
I just checked the SAFC.
Main Menu-------Etc-----
Under the ETC menu is 3 options
1/. Car Select
2/. Graph Options
3/. Sensor Check.
Under Car Select option I set it to 6 clyinder and throttle with arrow pointing to 1 o'clock position.
Monitor Menu
1/. Channel 1
2/. Channel 2
3/. Channel 3
4/. Channel 4
5/. Channel 5
6/. Rev (Y)
Under Rev option is the Karmen option which I selected and backed out.
Is that what you are talking about?
Cheers,
Roy
tte
Northern California
I did scroll up the menu under the ETC screen and saw the sensor type...I selected Karmen...
Thanks guys...
Car runs fine now.
Cheers,
Roy
