SAFC Pressure in and out Settings
turboa7mgte
HECK YES I DID!!!
Delavan, WI.
My car Pulls timing like crazy at 5k for a little bit causing a nasty bit of lag from 4800 to about 5200 RPM then takes off like crazy. I have messed with the Pressure IN and OUT settings and have gotten varied results. have and of you Speed Density guys have this problem?
I have the turbo A ECU and Turbo A map sensor and the complete turbo A motor, So everything should be all matched up.... but I am kinda perplexed as to why it is pulling timing like this. Before installing the Turbo A map sensor It would not come out of this timing pull... it would just sit at 5k and build boost.
So I am thinking that the SACF settings are just wrong.... I want to get this running Perfect so i can sell the Turbo A set up in good running condition to a lucky 89+ owner.
