safc newb
derK
CANADA
what is the blue wire, yellow wire, and white wire for?? those are the only hookups not installed for my S-afc. The PDF on apex-i says that the purple wire is for knock, however i don't have a purple wire. IS that the blue wire they speak of??
Also how do i RESET all the settings on the s-afc?? or better yet, what is a safe setting for me when i just installed my lexus afm/580s/fpr...but yet to install my walbro. I basically want to run my car until i burn off my full tank of gas, so obviously i want it to run conservative and safe for now.
dbsupra90
toonar
indiucky
derek-
there isnt a blue wire, only purple so that must be what it is.
the yellow and white are for the airflow signal when you have a maf/map
as far as the reset, not sure which model you have. in the menu there is a selection for reset all. it might be under etc, i dont remember off hand.
i would just set the fuel correction to 0%. if you do it that way it would be the same as not having it hooked up.
TobyCat
470
Vancouver BC
the reset is under settings menu, and when that is done you must power cycle the SAFC for the changes to take affect. IE, turn your car off ;)
This will put the airflow correction for all RPMs back to factory default of zero.
