I just installed an safc neo. Motor is stock 1jz. soarer ecu/550cc injectors/japanese tuned ecu/stock map sensor. It starts right up on the stock computer. With the safc, it does not start
I wired my safc neo into a jumper harness and am having a little problem setting it up right. On the screen where you select the sensor type, it ask for in and out settings. What should i set these to?? I searched but the only thing I found were the low and hi throttle settings
