I hope this hasn't been gone over before, I have searched and haven't found anything. I have had my SAFC II wired in for almost two years, just piggy backed off the ECU, with inputs for B+, E1, IGT, and VTA. So when I wired in my Zeitronix I went ahead and piggy backed on the SAFC II wires, since I figured they shared many of the same inputs and then I wouldn't have to hack into the stock harness anymore. So the Zeitronix and SAFC II are on the same B+, IGT, and VTA. The only thing I didn't follow verbatim from isnms posts on how to wire the two was the ground. I used the E1 for both the SAFC II and the Zeitronix versus the E1 for the SAFC II and the E01 for the Zeitronix. I figured a ground was a ground, unless it is too much. I went ahead and cut the OX lead on the ecu and connected the ecu side to the Purple narrowband output on the Zeitronix. I also tapped into the ECU's vf wire and ran it to the user 1 on the Zeitronix.
SO... When they are both connected neither seems to be on. (car running) The Zeitronix doesn't show any data on my computer and the SAFC II is off. When I disconnect the Zeitronix harness, the SAFC II turns on.
So which input is causing the problem? Should I not be trying to run both of the same E1 or B+? I can't see how IGT and VTA inputs would have a problem since I would have to tap into them anyway. However I don't know if it was "bad form" to simply tap into the SAFC II existing leads versus making new taps onto the ECU's wires.
What could be my issue? What can I try? Any help or advice would be greatly appreciated!
Thanks!
Trevor
Thanks!
Trevor
