Safc II TOYOTA WIRE HARNESS COLORS
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
MDCmotorsports said:
Guys, I already have the Apexi manual, and I have this thread:
http://www.supramania.com/forums/showthread.php?p=229705#post229705
What Im wanting to know is what COLOR THE TOYOTA wires are that the SAFC wires tie into.
Thanks!
~Jon @ MDC
ummm go to apexi web site and look up the wirieng book it will show a ecu pin out fallow it and you are gold if i remmber right it t2b pin out in the book
cheers
IHI-RHC7
"The Boss"
Oregon
Jon, colors are in the TEWD.
There's the pics of all wires for a 90 ecu, I have the 89 tewd at home, but it's late 89, so it should be the same, the only difference would be pre 89 harnesses..
chriso
Supranian
Bay Area, CA
This is how I did mine for a 90 Turbo. The connectors for the ECU are labeled in the TSRM as R(26 pins), S(16 pins) and T(22 pins). I don't have the info available for the 87-88 however. All wires are to be tapped into and sealed. The only wire that needs to be cut is the Light Green/Red (S2) for the airflow signal.
SAFC-II to Vehicle ECU
Red (Power) to +B - Black/Red (T12)
Green (RPM) to IGF - Light Green/Black (R3)
Purple (Knock Sensor 1) to KNK - White (Clear) (S5)
Gray (Throttle) to VTA - White/Red (S11)
Brown (Ground) to E1 - Brown (R14) (Closest to ECU)
Black (Ground) to E1 - Brown (R14) (Away from ECU - Harness Side)
Pink (Airflow Output to ECU) to KS - Light Green/Red (S2 - ECU Side)
Orange (Airflow Input from AFM) to KS - Light Green/Red (S2 - Harness Side)
Hope this helps. Good luck on your project! Oops, I think I posted in two threads.
EvoLuTioN
no-JZ Your Mom!
Mar 10, 2006
508
Bed
weird thing, after I took up the Airflow wires, the car rpm on a cold start drops really fast and when I accelerate while parked it stalls, and on the SAFC 1 it doesnt read out any airflow/kar
chriso
Supranian
Bay Area, CA
I don't know anything about the SAFC-I. The wiring I did earlier in this thread is from my SAFC-II as stated in the title.
Squid699
Manic Mechanic
Chesapeake, VA
Chriso, you are a great man for putting that up. Should save me some issues when i install. after counting off the wires you mentioned, i still have a blue, yellow and white wire left. Are these not used on a Karmann setup?
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
the leftover wires are for pressure,flap airflow meters. I havnt wired up my knocksensor but I still get a knock reading from my safc-2 It says in the manual to connect to the knock sensor with the highest output and there are 2 wires, one above eachother.
