safc-II Adjustment
Status
Not open for further replies.
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
I think I need to adjust my SAFC-II . I am getting a WB it will be installed monday. Under WOT I get black smoke. Am I correct in thinking its too much fuel? I have the boost set to 1.5bar (thats reading the gague) I have a manual boost controller. Am I correct in thinking the safc has to be changed because of the boost level. (it was set to .5 when it was tuned on a dyno) I am not boosting all over town untill the wb gets here and its tuned correctly. However I am just trying to understand that when I see black smoke under heavy acceleration that means too much fuel and an adjustment to the SAFC II will correct this.
thanks for the info. I am learning so much as I read here.. I think I spend more time here sometimes then doing my job! hehe..
97TSiAWD
In need of more traction
Jul 18, 2006
124
Michigan
Yes, a large amount of black smoke coming out of the exhaust is due to excess fuel. And yes, that can be adjusted using an SAFC. As I think you know, just don't make any adjustments until you have the wideband installed. It's best to leave it running rich for now than to over-adjust and have a lean condition.
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
Yes. thank you. I wont mess with it. I wanted to know if I was thinking correctly. The Wideband is gonna be here monday, and I will install it monday night. I had an LM1 in there so the spot for the sensor is still there just plugged. So it should be easy. I bought the UEGO 6 in one wideband
from LEGNA . Great seller by the way. Got it out fast with tracking.
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
Got the WB installed and after the car warms up when I stop at a light and idle the gauge goes over its limit. (17 is the last # I see before the --- ) at idol what should it be? while going about 80 on the bridge it seems to be arround 15 - 16. I need to learn more about the safc before I mess with it but I dont want to blow up while I am trying to learn.
isnms
United States of America
Oklahoma
i80.photobucket.com
at idle should be ~14.7:1 A/F
check for vacuum leaks
also check VF
MDCmotorsports
Indy 500
www.MDCmotorsports.com
also check VF
^Correct. The AF at cruize and idle will vary from 14.5 to 15.6 ish.
Under boosted WOT AF should be no leaner than 12.0 if you are on a stock engine.
Remember also, that the more fuel you take out on the safc, the more timing goes into the engine.
Status
