OK i am running 57trim, 560cc, lex, 2.5 ic kit, 3.5" turbo back, afpr 36-38psi, safc2. altitude 6600, and wanna run lower boost with more power (10-14psi) if possible
I have not had a chance to get back to the dyno for a retune, and my tuner is not all that knowledgeable of safc. He has it set a -5% across the rpms (1k-6k) no changes, it is however running around 10.5afr, still rich. and put down 355/403 on 14psi. and 371/416 (untuned) 18psi. around the same afr maybe richer.
I wanna know why he ran the fuel decrease the same? is that correct or should it taper, and have more fuel taken out at the higher end?
So if anyone can help me out setting the tune, or atleast the fuel correction, i would appreciate it.
also all of the other setting are set correctly, just curious about fuel correction only.
