Routing Aristo 2jz harness
madsupra88
BoOoOoST
Sep 17, 2005
1,245
Detroit,MI
WOW this is great info, i was just about to start hacking my 2j harness, and thought about just mounting my ecu under the steering column, so i searched and found this thread!
Did you tap all your guage wiring by the glove box, or did you tap into the harness behind the cluster?
thanks
thanks
The only thing that i dont understand by this is the fact that it it isnt longed enough to reach the stock hole. but for some reason it will will reach from the gas pedal and go that far through the cluster
