Story is when I start my car up it idles high when it's cold like normal then after like 5-10min it starts to drop and when it gets warmed up a bit the idle sometimes bounces like 200 rpm or so it sounds like I have big cams or something. Then when I back out or moving up a little bit like parking and such where you drive then engage the clutch to shift into neutral the idle will stumble and sometimes stall out usually if I turn the A/C on it will prevent it from stalling but not all of the time. I cleared the codes and checked for some but I get nothing, I have a Lexus AFM with new sensors, Precision 550CC injectors, and 3in divorced downpipe. Now I think this problem is caused by my blow off valve because when I hit boost I feel it pull until it gets to max stock boost levels at about 3,000 RPM then it feels like it's out of puffs also when I left off of the throttle I hear a sort of strange sound I can't really describe it sort of sounds like taking a swig of water and whistle with it in your mouth. It's a bad description but I can't think of how to describe it right now lol. Yesterday when I was removing my Blitz boost controller because apparently the solenoid for it doesn't work because I couldn't control the boost I removed the factory blow off valve and blew through it and felt it come out of the other side. I think that is the reason why my boost controller wasn't actually working and probably the cause of my idle/stalling problem but I wanted to get some other info on what to check for and how to do it. I thought about spraying brake cleaner on vac lines and turbo hoses to see if they are leaking or not sealed properly and wanted to know if there is a better way of checking for leaks or what areas to inspect. Oh and in the morning I am taking an old Tial bov that a friend of mine gave me to my shop guy to see if he can fab something to replace my charge pipe and see if it works and solves my problems.
I have done a lot of research on this issue but as usual my problem is not the same as 99% of the stuff I come across lol.
