Rough Idle after cruising with cruise control?
TrqMnstr
HKS Whore!!!
Oct 31, 2005
442
Los Angeles, California, United States
It happened for the first time today. I'm cruising at a constant 70 MPH no problems, when I exit the freeway though different story. My Supe feels and sounds like it's bogging, but a soon as I get on it it'll go away.
Normally it idles @ 1000 rpm no lower no higher
During Symptoms@ 500 rpm
What should I be looking for??
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
1. check codes
2. check o2 sensor
when using the cruise, the ecu reads o2 feedback for mixture adjustment (open loop).
btw- has your mileage changed at all since this started happening? I had the exact same prob a while back, pulled codes, did a diag test on the o2 sensor (it failed) replaced it, solved the issue...
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
your car idles at 1000rpm's normal??
stock should be 650 or 700 (650 i think).
so...maybe your normal is actually screwed up.
maybe this has nothing to do with it but... today i was turning off my car and turned the key really slow...my gauges and electronics cut off but my engine stayed running and i still had throttle control of course ...but my idle went goofy and was probably around 800-1000 in my best guess. it dropped back down to 650 when i turned the key in the other direction though. so maybe....its electronic. that's all i have. just sparked a memory :D
i forgot to mention the COLD idle is up there...but not once heated.... it should sink back down
TrqMnstr
HKS Whore!!!
Oct 31, 2005
442
bwest said:
1. check codes
2. check o2 sensor
I was backprobing O2 sensor and got no voltage readings in any of the three wires. Maybe I found it?? Also this might solidify my findings, On cold mornings when I start the car check engine light is off but, when I give it some gas, It comes on.
