Roll cage advise
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
So It is if your going over 135 mph you gotta have a nhra approved cage regardless of times. Question is are there any bolt in cages that are approved or will this be a custom fab issue. I think i read Duane got booted for not having a cage with his last run. I still want to be able to get in and out without having a bar across the door opening.
ANY ADVISE?
Thanks
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Bolt in cages are for show, weld in cages are for racing.
look on S&W race cars for the cage you are looking for, then have it put in (will need minor mods IIRC)
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
get the kirk racing cage it has better fitment and more options than the sw cage.
http://www.kirkracing.com/
however ultimately i still recommend a custom cage over any of these off the shelf cages. never go cheap on safety equipment
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Kyle speaks the truth boys and girls. Safety is not something you go "bargain" shopping for.
VooDoo
Mar 20, 2008
342
Valdosta ,Ga
I agree 100%. I know our strip is a NHRA sanctioned track and I will be able to get it inspected there next event. Whatever I do it must pass inspection. THATS my concern. If it dont I wasted $ on something that is not gonna do its job.
dbsupra90
toonar
indiucky
if money isnt a concern, i would def suggest going chromoly. its twice the price but atleast 1/2 the weight.
also i've never seen any of the bought cages that didnt have to be tweaked and notched, but easier than a full custom cage. not a lot of people around that know how to build a certified cage. its more than welding some tubing together.
lastly, if you are getting forward bars id get a swing out for the driver side. may not be necessary for you, but i'm a tall guy and it isnt a lot of fun to squeeze over the fixed bars.
MDCmotorsports
Indy 500
Careful with this info Dave. Chrome molly weighs just as much as steel tubing, but its stronger pound for pound than mild steel or DOM, therefore you need less making a lighter cage.
Also, when requesting a chrome molly cage, request to see the welder/fabricator's welding skills. Chrome molly is very easily over heated if not welded properly.
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
Poodles;1428258 said:
Pound for pound, no, but if properly made it's every bit as strong. It wouldn't be allowed if it was inferior.
You really should think twice about saying some things.
Cages are not all rated the same. And yes inferior cages are allowed to run slower times.
gaboonviper85
3,236
Northeast Philly
With all due respect poo you're so effing wrong it's sick! Chrom is about 2.5 times stronger in everything...yes a mild steel cage works but it's not near as strong as a chrom cage made exactly the same! You're a mod and should know better than too spout off ignorant comments
gaboonviper85
3,236
Northeast Philly
Poodles;1428305 said:
Reading comprehension owns you as well as the facts: http://www.nhraonline.com/contacts/tech_faq.html
Tell me again, if it wasn't as good, why is it allowed?
Cause mild steel works....but as strong it is not...chrom you can have a lighter cage that is much stronger than a mild steel...not everyone has the bank for chrom! Come on poo this is simply retarded you're agruing this!
funky_monkey58
Apr 3, 2006
1,307
St.cloud MN
You have only reading comprehension and google to guide you.
Would you like me to do a stress analysis of chromoly tubing vs mild steel? I do have access to the testing equipment.
It is allowed yes, but beyond a set point you need to have chromoly.
Does not mean every bit as good as.
Read the links posted and know the facts. Chromoly is downright DANGEROUS if not properly welded (and the risk of this is very very high, if they're having issues on top fuel dragsters, you think you're going to have your cage done perfect?).
As in the link I posted since you fools don't know how to click
The wall thickness spec is higher on mild steel and it's going to be heavier. Nowhere did I say anything about "made exactly the same."
Reading comprehension owns another one.
Also conviently missed my first link...
