been driving with rodknock for a while now... and within 1 month im gonna pull the engine and rebuild the bottom end.
i cant find anywhere in the tsrm that says to check the connecting rod big end for roundness, but i remember seeing it somewhere. anyone?
what im planning on doing is buying an already cut crank with main and rod bearings and replacing that with all seals, and new oil pump. ive already had the motor out once to do this because of knock, but even though the bearings were shot, the crank still looked good and measured up within specs according to the tsrm. plastigauge was also good.
so, what should i do? should i look for a good set of used rods? i know that they are the same for na and turbo, so i should be able to come by at least 6 good ones. if i do have to do this, im gonna put in new pistons with rings and pins along with the new rods. but if i dont have to break the seal between my block and head id be happier. it just got a mhg 2000 miles ago, and im nervous about it re-sealing...
rodknock is the only thing left to this thing that i havent completely fixed yet, and i just want to do it once. thanks in advance for advice or experiences
your turn:
your turn:
