hey i was wondering if someone can provide me with the specs on the 7mgte ...things such as rod diameter, length, wrist pin diameter, etc. im trying to get some rods done and i need to provide the company with the specs thanks
Unfortunately, I just recycled my pile of 7M parts, rods included. I'm SURE there's someone out there with an engine torn down, or doing a build that would do this for you. You would probably get a better response from directly asking someone who you KNOW has an engine apart with a rod in their hands.
C.C length 5.984" 152mm
Big end bore 2.166" 55.016mm
Crank pin diameter 2.047" 52mm
Big End Width .975" 24.765mm
Wrist Pin bore. .8665" 22mm
Small End Width .975" 24.765mm
