Already have an NA, no lsd though. looking to lower my highway rpm cause its around 3500rpm at 70mph plus it would be nice to have a taller gear set if i do an engine swap.hvyman;1833277 said:Mk3 have a 8in diff. I believe it will fit but why. If you wanted different gear ratios just get na LSD with the 4.30 gears and swap it in.
Idk for sure if it's a direct fit and work with the LSD or not.
Really? where from? cheapest i've found is $300 on ebayhvyman;1833377 said:Ya but a 3.91 would be better. I liked the 3.91 LSD a lot more than a open 4.30.
Doesn't really seem worth it to change gear ratios and rebuild the diff and not get an LSD. A whole LSD is like 100-200$ complete pnp.
