right singal light
doom26464
Research...research
Saskatoon SK, Canada
my front right signa lights arn't working. The back one works but not the front. When ever i signal to the right the signal flasher on the dash flashes really quick makes a really fast tick tick tick tick tick tick tick. I check the fuse in the fuse box and it looks to be fine. checked the bulbs and there all good as well. Where do i start looking besides this help????:1zhelp::aigo:
doom26464
Research...research
ok here is a better description of what i did
ok here is what i got. took out an old skool volt detector( it has a light inside of it so when it detects voltage it lights up. and you have one wire coming out if it for a ground) so anyways I took the signal housing out and there is a plug that connects too it. unlpluged it from the signal housing and set the housing on the work bench. inside the plug there is 3 prongs. Went and turned the car on and turned the signal on too right. went and tested 3 of the prongs. 2 of them had nothing volt tester didn't light up...how ever the 3rd one did light up and the volt tester blinked in rythem with the signaler. sooo i dunno what the hell is going on. I hate wiring its sort of my weak spot
