reuse composite headgasket engine hasn't been ran
vCo2v
52
Tacoma
Roughly a year ago I cleaned up an engine put a felpro gasket and arp head studs and torqued it down. Its been sitting on an engine stand ever since. I got a new supra and the stock engine has been holding up fine. I feel as if everything is running right so far, and now I'm itching to up the boost, but I wouldn't want to unless I put arp studs and torque it into spec. I know I can reuse the studs from the engine on the stand, but what about the gasket? Its never been used.
BryanDyer
654
Georgia
I wouldn't use it since it has been torqued down it has already been compressed which puts you at higher risk of being prone to failure. What is it like 80$ gets a new one? It's an 80$ worth it.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
7M4EVR;2001559 said:
neh..torque the stock ones down...turn up the boost, then WHEN it blows...swap motors haha.
Yup. Keep an eye on it and run it as is. let us know how much it'll hold and for how long. haha.
If you've already torqued down the head I wouldn't reuse it. MHG? sure. Composite? no.
