Resurrecting the MA71
TRDaddict
Hey all, I'm Josh and I live in Knoxville, TN. I've been the owner of a 1989 Supra Turbo targa since 1996. Unfortunately the turbo died back just before Christmas of 1999. Well, I decided to rebuild the engine and replace the CT-26 with a T04B copy of the HKS Sport turbo kit. I got almost all the parts together including the HKS intercooler, F-CON, EVC IV, VPC, GCC II, 550cc injectors, tons of engine work (knife-edged and balanced crank, 11lb Mueller billet aluminum flywheel, ARP head studs, HKS 2.0mm stopper type metal head gasket, some mild head work, Walbro 255, 550cc injectors, AEM adj. rising rate fuel pressure regulator, HKS SSQV, turbo back 3" exhaust all mandrel bends, Greddy 60mm intercooler piping, Clevite 77 bearings, Total-Seal rings, HKS 40mm external wastegate, all new gaskets and seals...Tein HA coilovers with upper pillowball mounts, Greddy 60mm peak and hold warning meters (EGT and wideband A/F)..well the car has sat for ten years now after all that work, and just now I'm getting around to finish this project. In the past few months I've picked up a Cusco 6 point roll cage to hopefully fix the nasty chassis flex, a Cusco front STB, a Whiteline 30mm front anti-sway bar, SSR GT3 20x9.5 wheels, A Megan aluminum radiator, Gates Racing radiator hoses, a staggered set of Yokohama AVS ES100 tires, and Odyssey battery, a 34 row oil cooler, and some BC Stage 2 cams. I'm going to get some cam gears and finish plumbing the fuel and oil and coolant lines, as well as an 3 qt. Accusump and try to get the thing running over the next several weeks. I'm sure I'm forgetting some parts...oh yeah, a set of Sparco Torino 2 seats to replace my heavy stockers. Pics will come as soon as I get over to my mechanics and start piecing some stuff together, ordered a few pieces from Arizona Performance today also...waiting for my buddy in Okinawa to send the the C's shifter he bought for me about 8 years ago if he can find it...Nice to meet you all, sorry for the long post.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
welcome long post is fine...sounds like you got a montser on your hands cant wait to see the pics...good luck with your build...
TRDaddict
well, car was towed to my body man's house, I ended up getting Shine Auto Project's widebody CF fenders, need to take them to him next week along with my Turbo A duct and shine lip spoiler. Oh I bought a BBK 6 pot wilwood sl6-r calipers and 14" rotors, went value (cheaper for the single piece larger rotors) over AZP's kit that would have been lighter (2 piece rotors)....and got wider rear SSR GT-3's for a staggered setup and deeper rear lip....and my mechanic finally told me the rings I ordered fit the Probe +0.5mm pistons, so the set I ordered had 4, I had to order another set of 4 to get enough rings, should have asked when I ordered the first time...the ball is rolling, just slowly, I'm at the mercy of my mechanics at this point, block is back from the machine shop though...
TRDaddict
sorry, took these pics back in July....
---------- Post added at 12:19 AM ---------- Previous post was at 12:18 AM ----------
this is what happens when you build an engine, and let it sit without running it for 5 years
---------- Post added at 12:21 AM ---------- Previous post was at 12:19 AM ----------
3" turbo back mandrel bent exhaust, HKS stopper type 2mm metal head gasket (Best sealing head gasket available. Ability to hold well over 20 psi of boost pressure)....now Cometic makes some exact copies
Brian crower 264 cams, head has been port matched, 3 angle valve job, new valve stem seals, BC valve springs and titanium retainers
Stock forged crankshaft, knife-edged and balanced to within +/- 0.5 gram, most of the counterweight has been cut off
Spec Stage 3 carbon semi-metallic 6 puck sprung hub disc, 520 ft lbs torque holding capacity
HKS cast T4 manifold with 40mm HKS wastegate 11 lb spring
GarrettT04B V-Trim T-4 Divided Inlet V-Band Outlet 1.15 A/R 300-450 whp
Odyssey battery http://www.odysseybatteries.com/ and Gates racing radiator hoses with constant torque clamps
old stock CT-26 (bad bearings)
stock pistons and rods (replacing pistons with Probe Industries forged and shot peening the rods) rod bearings are Clevite77 tri-metal (not made anymore, the ones that are sold are rip off sold under that name)
Earl's 43408ERL 34 Row Oil Cooler -8 AN
not pictured.....AEM Series 2 Plug & Play EMS 89-92 Toyota Turbo, all sensors
HKS intercooler and hard pipe upgrade
HKS flow (20 in-H2O): ~310 CFM (500+hp)
Stock flow (20 in-H2O): 169.0 CFM
---------- Post added at 12:24 AM ---------- Previous post was at 12:21 AM ----------
oh and in person the color difference between the seats is not nearly as striking....may have to get them dyed to match each other though...that's the problem with buying seats 10 years apart...
