So my valve tick is quite loud now I am noticing it more ever since I got my cat back installed, no more open down pipe lol. From what I have gathered I check clearances with a feeler gauge with the cam lobes pointing straight up and if they are out of spec I pop them out with a screwdriver and magnet and get replacements at the dealer then put them in and crank the engine for 10 seconds to seat the shims apparently oil pressure won't build up enough to spray oil everywhere and re-check clearances. I want to be sure this is correct and I do not have the time to remove my cams and don't have the tools to pop out the shims and check the thickness and apparently I do not have to do that I can do what I said above and use a feeler gauge while everything is installed. I saw a video by Numba1stunna on how to check clearances and he's helped me a great deal when I did my head gasket replacement he seems to know his stuff quite well my car still running over a year later is a testament to that lol.
