Replacing TEMS shocks w/ KYB's?
johnathan1
Supra =
Aug 19, 2005
5,056
I desperately need new shocks...and the KYB's seem like a good choice...anyone have any input?
here is a link with the lowest price I could find: http://www.rockauto.com/catalog/catalog.php?carcode=1278468&parttype=7560&a=FRc1278468k502744
I would be using them with the stock springs, will they change the ride height at all?
Will I have to do anything other than delete the TEMS actuators to make these fit?
What usually needs to be replaced (what else should I buy now, while I'm there) when changing shocks...
Anything else i should know about them??
Thanks everyone!!
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
i got KYB's. They work great. While there i also changed my upper strut "bushings".
MA70Supra88
Boostless
Boerne, TX
just unplug and remove the tems actuators and they will work. if you want to do a better job of it you can remove more things, but it isn't necessary for the new shocks to work. the ride height should stay the same. i would replace the bump stops while i was in there.
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
I would go with a more slight upgrade and get the GR2's. They're about $27 each at a website I found them at, all four for $117 shipped altogether, which is an awesome deal.
-Matt
johnathan1
Supra =
Aug 19, 2005
5,056
Oh, I thought the ones that I posted were the GR-2's.
87SilverSniper: Bushings? Are those the same as the Bump Stops?
GotToyota: Where did you buy them from, that sounds like a pretty good deal. Also, what suspension setup are you running? Your car seems a bit lower than mine...
