need to replace the hose off the throttle body, and the 2 hoses coming off the valve covers. just figuring I might as well do the rest of the hoses too. Ive seen people use this clear pvc tubing, that has a white reinforced weave. Its pretty flexible, but I'm unsure as to how it will withstand oils and heat. also wondering if anyone knows the sizes (ID) of the various hoses. for the hose coming off the throttle body, is an oem replacement my only option, as it is one size on the TB end and a different size on the tree end? I'm hoping for a solution that won't break me, as the routing will all change when I go standalone, which hopefully wont be much longer
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=1201&P=2
also wondering if its possible to replace the hose's and metal line going from the ISC to the accordian with just one flexible hose?
