I have a 90 with abs and i need to replace a broken hub bolt. I have looked at the trsm and want to know if i have to disasemble the axle hub from the axle bearing to get the bolt to clear the abs sensor rotor.
I know without abs it is much easier to punch out the stud and replace.
Do i have to disasemble the bearings and break the oil seal? If so, I may as well go ahead and replace the bearing and seal while i am there?
