Replace Green Loctite or use FPIG on Oilpan Bolts?
improved
Running!
Apr 4, 2005
195
California
Hello gentlemen,
I'm in the middle of replacing the oil pan gasket on my 1J. I see green loctite on the oil pan bolts. I've never seen this before. Usually, on my 7m, the bolts have been covered with FPIG.
Should I replace the green Loctite or can I use FPIG?
Thanks,
Matt-
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
improved;1125110 said:
Hello gentlemen,
Thanks,
Matt-
tsrm just calls for the silicone, its all i used no probs on any swap ive done. just dont use too much
YotaRob
U.S.Navy
Jun 18, 2008
177
Great Lakes
I noticed the loctite also when I did mine. I just went with FIPG-black and its all ok. That stuff is amaizing, I even use it instead of exhaust gaskets. After the turbos of course.
tlo86
Jul 24, 2005
3,914
Colorado
i saw it i thought it was just corrosion of some type.. as it wasnt on all of the bolts..
buy new (small) bolts though if you plan on torquing them :) all of mine broke when i tried to torque the old ones hehe
improved
Running!
Apr 4, 2005
195
California
I finished cleaning all of the small bolts, they look fine. There doesn't seem to be any visual signs of stress in the metal. I think they will be fine for the 6.5lbs of torque.
Thanks,
Matt-
tlo86
Jul 24, 2005
3,914
Colorado
Thanks,
Matt-
6.5? hrm i thought it was 15
edit: 15ft for 12mm head 30 for 14mm are the rest of the bolts 10? i cant remember honestly.. lol
