Removing Rear Timing Cover???
Sik89supra
Delta PA
Would it be ok to remove the rear timing cover to reseal it, or would it cause problems with the headgasket? Would i have to remove the head or can it stay in place??
gaboonviper85
3,236
Northeast Philly
The rear timing cover has oil flowing down the back of it....it needs to seal against the headgasket and block.
To the op:
good luck getting it to seal without taking the head off...I say give it a shot but if you're still using a stock gasket then odds are it's not coming off easily!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
To the op:
Just plain not going to happen. Save yourself the frustration, pull the head and go at it that way.
